Nidhin_Kuttikkattu_Rajeevan
Oct 20, 2023 10:40 AM UTC
List down all the possible attributes in figma property in plugin
Hi Could I ask a question?
I have a componet called Fruit. I created an intance of Fruit in my Figma document. It has properties like colour, origin
Suppose possible options for colour are Green, Red, Orange, DarkRed
Suppose possible options for origin are Indian,Netherland,England,France
It will come under variant properties. So in my plugin, I will set colour=Green using setProperties API.
I read this property Green Blue etc from a txt file. So sometimes there is a chance that Green is green(Capital letter,small letter issue) and Figma plugin throw error if there is no exact match. So in plugin I would like to read all the possible combinations of colour before throwing an exception. How can I do that?
For example, if I click fruit instance node, can I iterate through its properties like colour and origin then list all available values of colour and origin to a string array? So before I assign colour = inputFromTextFile, I can check if InputFromTextFile is Green or green.
Oct 20, 2023 11:45 AM UTC
@tank666 any guidance tips?
tank666
Oct 20, 2023 12:18 PM UTC
Oct 20, 2023 12:19 PM UTC
I have seen this. But how can I iterate the items in the combobox of a property. When I try to print, it is returning only the present value
Oct 20, 2023 12:25 PM UTC
for example,
if Apple is an instance node, when I select it, I can see the properties on right side,
it will presently shown as
Colour = Green
Origin = India
But if I press green, I will get a combo box option, other values. So I wish to iterate those values when I select an instance node.
tank666
Oct 20, 2023 12:30 PM UTC
Sorry, but I can’t confirm this. The output should be something like this:
  'PropertyName 1': {
    type: 'VARIANT',
    defaultValue: 'Default',
    variantOptions: ['Default', 'Variant 2', 'Variant 3', '…']
  'PropertyName 2': {
    type: 'VARIANT',
    defaultValue: 'True',
    variantOptions: ['True', 'False']
Oct 20, 2023 12:39 PM UTC
Exactly that variantOptions is I am looking for. But it is not showing in my log.
I did as this.
let mySelectedFruit = currentPageSelection[0] as ComponentNode;
console.log(mySelectedFruit .componentProperties)
It is not showing VariantOptions
tank666
Oct 20, 2023 12:42 PM UTC
Check the ComponentSetNode.
Oct 20, 2023 12:59 PM UTC
ComponentSetNode?
I tried as this
let mySelectedFruit = currentPageSelection[0] as ComponentSetNode;
it returned undefined 😦
tank666
Oct 20, 2023 1:05 PM UTC
InstanceNode.mainComponent.parent.componentPropertyDefinitions
Oct 20, 2023 1:08 PM UTC
Fantastic. It prints. But I am pretty sure, if you not give this tip, I would have keep struggle with this. Thanks alot. Now I will try to iterate that VariantOptions. 🙂
Happy weekend
