Susanne
March 22, 2022
Libraries enabled but components are not showing
  • March 22, 2022
  • 16 replies
  • 15351 views
I am new to Figma (transitioning from sketch). I just had to buy the professional plan to experiment with libraries. And thats where I got stuck:
I have a library file ‘documentA’ published and enabled for my team in ‘document B’ (I am on the pro plan). But I cant see components! It just says “…explore libraries…” and when I click on it it shows me that my library is enabled.
I hope this makes sense — I’d love to upload screenshots here but I dont see any option to do that. Is there actually a way to get real customer support?
Thank you in advance for your help!
David_Villarroel_Escorza
February 15, 2023
Reboot my Mac, install an Figma update (at the same time) and solved this issue. In my team, I was the only member with this issue, so I invite to do the same every time Figma fails.
Hope this help. Regards everyone.
March 16, 2023
Hi there,
nothing of it worked for me, unfortunately. So I had to detach & recreate the components & publish them again.
Toph-r
July 25, 2023
Hey everyone be sure you have opened the Library File on Figma and double check the following:
  1. Libraries are enabled.
  2. The design file has been moved to the project you are working on.
  3. The design file has been published.
  • Step 1 can be completed by clicking on Assets → Team Library icon (looks like an open book) → Clicking “Enable libraries for all team files from your team settings” hyperlink at the bottom and following the prompts
  • Steps 2 and 3 can be completed by clicking the drop down arrow located next to the design file name at the banner on the top of the page
After the above is completed navigate to your Design File Project → Assets → Libraries. This will display the Library and Components you have linked and should also have the button to enable/disable the library on your Project.
Hope it helps!
August 30, 2023
This solved my problem. Thank you so much 🙂
December 1, 2023
hey guys I’m new here, how do i find mobile wireframe UI Kit?
Marsy
worked for me, thanks!
