Aamir1
May 11, 2023
layoutAlign not working
  • May 11, 2023
  • 307 views
If a parent is set to auto-layout, and it’s children are set to layoutGrow = 1 and layoutAlign = “STRETCH”, the children should fill the parent container both horizontally and vertically, right?
I’m doing the same but for some reason layoutAlign is not working 😦
Here’s the code (Please check out the ‘//Creating a frame for column’ code block… that is where the problem is):
figma.showUI(__html__, { themeColors: true })
figma.ui.resize(300, 250)
let bounds = figma.viewport.bounds
let key = "93fecd27ee35164ce296179f418dd122071b4ecc"
figma.ui.onmessage = async (pluginMessage) => {
  //Importing a component set and saving components as variables
  let componentSet = await figma.importComponentSetByKeyAsync(key);
  let regularCell = componentSet.findChild(e => e.name === "Property 1=Regular Cell") as ComponentNode
  let colHeader = componentSet.findChild(e => e.name === "Property 1=Column Headers") as ComponentNode
  let rowHeader = componentSet.findChild(e => e.name === "Property 1=Row Headers") as ComponentNode
  //Number of rows and columns got from user's input
  let rows = pluginMessage.rows
  let cols = pluginMessage.cols
  //Creating a frame for table
  let table = figma.createFrame()
  table.name = "Table"
  table.layoutMode = "HORIZONTAL"
  table.primaryAxisSizingMode = "FIXED"
  table.counterAxisSizingMode = "FIXED"
  //Resizing the table and placing in the center of the viewport
  table.resizeWithoutConstraints(regularCell.width * cols, regularCell.height * rows)
  table.x = bounds.x + bounds.width / 2 - table.width / 2
  table.y = bounds.y + bounds.height / 2 - table.height / 2
  //Looping through columns
  for (let i = 0; i < cols; i++) {
    let columnFrame = figma.createFrame()
    columnFrame.name = `Column ${i + 1}`
    table.appendChild(columnFrame)
    columnFrame.layoutMode = "VERTICAL"
    columnFrame.layoutAlign = "STRETCH"
    columnFrame.layoutGrow = 1
    columnFrame.x = i * regularCell.width
    //Looping through rows
    for (let j = 0; j < rows; j++) {
      //Creating a cell instance
      let temp = j === 0 ? colHeader.createInstance() : i === 0 ? rowHeader.createInstance() : regularCell.createInstance()
      temp.name = `Cell ${j + 1}`
      columnFrame.appendChild(temp)
      temp.layoutAlign = "STRETCH"
      temp.layoutGrow = 1
      temp.x = i * 0
      temp.y = j * temp.height
  figma.currentPage.selection = [table]
  figma.closePlugin();
