It is really hard on 4K monitor to target line to "fast swipe" +/- object size
Hello!
Currently I’m using 4K monitor (high DPI), and every time I need to adjust size of some elements in Figma - I facing with struggling to point with my mouse cursor on the exactly 1 pixel width line for trying to “fast swipe” its sizes.
ksn
Thanks for the feedback, and sorry if this has been making it harder to work within Figma.
I understand that, in your situation, the small line is hard to latch onto and adjust with your mouse. I think you’re wanting to use this because you’re able to see the adjustments in real time, is that correct?
I was going to mention that you can just manually change the percentage, but if that’s the case. I see why that’s not ideal, but I don’t have any additional suggestions. I will make sure to note this feedback when it comes to the UI.
333hronosAuthor
March 29, 2024
Mainly because it’s faster to swype object sizes and shapes with just one click (there is many of boxes like that in Figma), rather than clicking on the each text box, entering the value, and confirming it.
Yes, additionally also because I often need to see changes in real-time, in order to avoid correcting numberic values in the text boxes multiple times.
Previously I have used 1080p monitor, and these sliders worked fine, but now on 4K, despite the fact that it looks visually similar, it became really hard to targeting on to it.
Abdullah_Wasi
March 30, 2024
Can confirm this annoying bug, I’m using a Macbook Pro M2 16".
