Emily25
Apr 4, 2024 5:31 PM UTC
Issue with .png transparent backgrounds
I’m having the same issue! Confirmed that the PNG has a transparent background, every time I import it (either through importing media or just dragging the file) it has a white background instead of transparent.
ksn
ksnSolution
Apr 10, 2024 5:40 PM UTC
@Kayla7 I think this may be because transparency isn’t persisting when pasted into other programs – this may be a bit unorthodox, but can you try converting the .png file you have > pdf?
Then try dropping that export into FigJam. Curious to see if that will work for you.
Christine_Restivo
Oct 21, 2024 11:24 PM UTC
Thank you! This worked! However, now I have a different problem. The PNG image that is an off white color is now no longer showing up at full opacity when I use the multiply blend mode. The background does disappear, but the logomark is also now blended and doesn’t show up very well. What am I doing wrong?
Meghan_Dedrick
Nov 14, 2024 1:50 AM UTC
I know this is old news however, I found having the same issue. I did resolve myself, by trying things. I made a symbol in the quick actions (Illustrator) and this seemed to rectify the white background. BUT…clicking the image border worked like a charm;-)
soufiane.lahlou
Jan 22, 2025 8:45 AM UTC
I had the same issue today and I use the Desktop app on my Macbook Pro 14".
→ I was editing my FigJam files on my iPad Pro M4
… I kept getting the background on my transparent image.
Solution:
  • Copy & Paste your PNG to a Design file → My PNG now retains the transparent BG.
  • Now Copy the image from the Design file and past it inside the FigJam and you the PNG should retain the transparent BG.
I hope this helps!
Thank you, it worked, great workaround.
Mp Am
Mar 9, 2025 12:53 PM UTC
Come check out pngspace.net—the best place to find high-quality PNG images with transparent backgrounds. Whether you're a designer, marketer, or content creator, we've got a vast collection of PNGs just for you! 🚀🎨
Explore now: pngspace.net
