barnboy
Issue with creating a slider / carousel using code layer in Make
Having a real struggle with a code layer generating a slider using the Figma UI to upload images to the slides. Problem is that the images sometimes would upload and be fine, sometimes appear to but then not show after publishing, despite previewing fine in the code layer modal, sometimes the images would persist after uploading, sometimes not, if I swapped an image out for another, the new image wouldn't show on the next publish.
The issue isn't related to say the Image 2 picker as the bug happens randomly - although Image 1 does always seem to work. And if I add the same image that works in Image 1 to the other Image pickers, they work. It really is a puzzler. Unless there's another UI approach for a slider I can use (I know there's not one in Make right now)?
