Cyril_hzx
September 2, 2023
Is there a way to set different spacing in Auto layout?
in the image, it shows two spacing with the arrows, I’d like to set different numbers for the two spacings, but it seems like when the numbers are changing, the two spacings will change together and they always stay in the same width/length, can I set them individually?
iShot_2023-09-02_04.30.44
Pavel_Kiselev
Power Member
September 2, 2023
Nope, you cannot
IraX
Power Member
September 2, 2023
This should become possible, because we’re currently wrapping elements in additional auto layout containers to apply the appropriate spacing between two child elements and that is just wrong. I’ve seen this mentioned quite a few times previously.
Cyril_hzx
Cyril_hzxAuthor
September 2, 2023
😭thanks, i thought there are ways
Cyril_hzx
Cyril_hzxAuthor
September 2, 2023
yep, i also hope this can be realistic
Pavel_Kiselev
Power Member
September 3, 2023
Or you can make a spacer component and stick it in between other elements.
