Brenda Luu
May 26, 2026 7:21 PM UTC
Is there a way to only show editable fields in Bulk Edit in Figma Buzz?
My Figma updated from the old Edit Content panel to the new Bulk Edit view. When opening Bulk Edit, every single layer appears, whether it’s editable or not. The non-editable fields can’t be interacted with, while the editable ones can.
Right now, I have to horizontally scroll through all fields just to find the editable ones.
I know you can manually filter and unselect fields in Bulk Edit, but is there a way to configure this at the master template level so those settings apply to anyone who uses the file in the future?
Jaycee Lewis
Jaycee LewisSolution
May 26, 2026 10:48 PM UTC
Hey ​@Brenda Luu  👋 Thank you for taking the time to flag this.
Looking at the Help Center article for Bulk Edits in Figma Buzz, I don't see an option for template-level changes. Currently, the main workaround is the column-based option you mentioned. As noted in the article: “To give yourself more room to work, you can hide columns you don't need—click Settings to toggle individual columns on or off.”
I found a similar request for more flexibility here — Buzz improvements. Please feel free to add your feedback there as well! I'll also share your thoughts directly with our product team.
Thank you! — Jaycee
Jaycee Lewis
Thank you! — Jaycee
Rodrigo C
Aug 12, 2026 7:48 PM UTC
Chill, so if we’re creating this for a different team, I have to ask them to hide the columns so they can use the template? Did I get that right? This is a user problem?
Aug 12, 2026 10:58 PM UTC
Hey ​@Rodrigo C, thanks for chiming in here!
Yes, you read that right, and it's a fair thing to push back on. Thank you for saying it plainly.
Today, hiding columns in Bulk Edit is a per-person view setting. It isn't saved into the template, so it doesn't travel to the team you're handing the file off to. That's a real gap for exactly the workflow you're describing, and not something we'd want to put on your end users.
Two things that may help in the meantime:
  • Lock the layers that shouldn't change in the template. It won't hide the columns, but it greys them out so your team can't edit them by accident. The editable cells are the only live ones.
  • Audit your layer structure. Bulk Edit builds column names from layer hierarchy, so if two assets have identical copy but one has it nested inside a group and the other doesn't, Buzz reads them as different fields and splits them into separate columns. Tightening that up can cut the real column count meaningfully.
Curious how big this is for you. Roughly how many columns are you scrolling past, and is it one template or a whole suite you're rolling out? We can pass your feedback onto the Buzz team as feedback on template-level field visibility.
Rodrigo C
Aug 19, 2026 3:05 PM UTC
We don’t have that many, maybe just 2 or 3, but even just one ghost columns is confusing for non-figma users. I tried to audit my layers, my first idea for a workaround where only field layers stay on the frame would be to flatten all the cosmetic elements and put as a bg as fill but we can’t even lock frame fills. That means any cosmetic asset in a post that shouldn’t change has to be a layer that’s locked.
I apologize for my tone but we just convinced our marketing team to give Buzz a chance and this is effectively ruining our chances of adoption.
Mo Hady
Sep 9, 2026 7:36 AM UTC
