Jul 25, 2023 7:44 AM UTC
Is it possible to see/open variable library in figma as a viewer?
I’m working with developpers and they need to be able to consulte our variable library to integrate our design system (espacially the colors). Does anyone know if, when you are a viewer it is possible to consulte them ?
owen5
Aug 9, 2023 9:06 PM UTC
+1 - I have this question as well. Developers can view individual variables in dev mode, but they seem to have no way to view the entire list of variables anywhere.
Elaine_Cervania1
Jan 22, 2024 1:14 AM UTC
+1 badly need this
Ampier
Jan 29, 2024 5:05 PM UTC
@mathilde3
I created a plugin that should solve this problem. It allows you to output all variables in JSON or CSS format.
Figma
Kendra_Davis
Aug 6, 2024 2:29 PM UTC
+1, we need this to be able to collaborate with development partners outside of our org. It’s unrealistic to grant all devs edit access to Figma just to consume the information the same way we can visually.
Nov 11, 2024 10:31 AM UTC
I created a plugin that should solve this problem. It allows you to view and export all variables in JSON or CSS format.
https://www.figma.com/community/plugin/1434720635503158584/variables-design
Yoriiis
Mar 23, 2025 7:08 PM UTC
We use the Figma CSS Variable plugin in our team, which is case-sensitive and can export Figma variables in CSS. The next version will allow you to export CSS directly to GitHub or Gitlab for seamless collaboration between design and code.
Link to the plugin :
https://www.figma.com/community/plugin/1474166340745390696/figma-css-variables
I hope it meets your needs
