Jun 7, 2023 9:29 AM UTC
Interaction on hover state not working
i searched the forum but i can’t find a solution. My question is if it be allow to use interaction on prototype to change frame by click on an hover state in an instance of a component nested in another component. I couldn’t do it and couldn’t find any solutions. Can you help me?
i need to create a menu (like the angular material one), i can click on the icon to open the menu and i can hover the first item to see the effect, but if i set an interaction to change frames it doesn’t work.
I link a test file, maybe it explain better my idea
Figma – 7 Jun 23
Stephane_Popout
Jun 8, 2023 4:27 PM UTC
I would create a bigger component containing your button and the menu
And add a variant where the menu is opened or close
And it should work
Alberto9Author
Jun 9, 2023 8:49 AM UTC
Hi Stephane, thanks for your reply! Maybe i wasn’t clear enough. I already have a component like this.
but when i use an istance of it i can’t click the hover state to change frames. I set the interaction, but in prototype mode it doesn’t work
Stephane_Popout
Jun 9, 2023 11:37 AM UTC
I updated your file here:
Figma – 9 Jun 23
Here a video result
When adding interaction between variants, sometimes it does not work from the right side panel.
But it works if you use the white handle in prototype mode.
I don’t know why 🙂
Hope it solves your problem
Enjoy
Alberto9Author
Jun 9, 2023 12:08 PM UTC
Excuse me Stephane, this is what i meant. I hope this way is clear 😀
Stephane_Popout
Jun 9, 2023 10:18 PM UTC
I see
The way you want to do it does not work 🙂
This is why I did it that way up
Tell me if you find a better work away
With what I did you can link to the red one on click too
Alberto9Author
Jun 12, 2023 6:48 AM UTC
ok, I saw your solution, but to do this I need to have a component for each menu I need, correct?
Because if i had to link the component to a frame, if i need 2 o plus menu I can’t have a single instance with several interaction. is my think correct?
Stephane_Popout
Jun 13, 2023 9:37 AM UTC
You just need 2 variants with select open and closed normally
Alberto9Author
Jun 13, 2023 11:51 AM UTC
ok, but if i need to use that component in 2 different part of the file which had to link to different frames?
could it be because i have the main component in another page of the file?
Stephane_Popout
Jun 14, 2023 1:46 PM UTC
There are thousands of use cases…
In some you’ll need to duplicate your component states every times
What’s your use case ?
Are you building a library with a menu Button ?
Should the menu redirect to pages only ?
Alberto9Author
Jun 14, 2023 2:12 PM UTC
my need is to create a menu i could reuse in different frames, and when I open it i have to can link a voice to another frame. For example i have to create frames like this:
where, potentially, every item on the menu links to another frame. And i need to replicate this behaviour for several table around the prototype.
Yes, i have a file with 2 pages: one for the product and another for all component i need, and the component is shared to all file i create.
And yes, every voice links to another page
