Feb 28, 2024 6:00 PM UTC
Instances disconnecting when components are moved from one file to another in same project
I have been experiencing an issue lately that I have never had before. I have 2 files within the same team project, one used for components and one with the main designs. Sometimes, I like to create components in the design file and then move them to the component file once they have been approved. However, lately, when I cut and paste them into the component file, then publish them, the instances in my designs disconnect, and when I click on the instance it says “restore component”. I know to avoid this, I can publish the design file and then move the components, but I swear I have never had to do this in the past. Was this an update? Is it a bug?
Gayani_S
Mar 1, 2024 3:32 PM UTC
Hey @Kendall_Van_Horne, thank you for reaching out!
Is this happening in the desktop app or the browser?
I am not aware of any recent bug regarding component instances disconnecting when copy pasting at this moment. However, could you try opening your file and running a Quick Action called “Repair Component Connections”? This command has a similar affect to fetching the most updated version of the main component, without you having to manually change and re-publish the main component and accept updates in subscribed files. I’ve included some instructions on running the command below.
  1. Open the affected file
  2. From the main dropdown menu in the top left, navigate to the “Quick Actions” search bar.
  3. Search for “Regenerate component connections”
  4. Run this command
Please let me know if this resolves your issue, happy to help out further.
Mar 1, 2024 5:53 PM UTC
Glad to know it’s a bug and not an update, but I don’t see this option in the quick actions search…
Gayani_S
Mar 5, 2024 3:37 PM UTC
Hey @Kendall_Van_Horne, apologies for the confusion! I meant “Repair Component Connections”.
Please let me know if this resolved your issue and also can you please confirm if this is happening in the desktop app and in the browser?
Mar 5, 2024 5:00 PM UTC
Thanks-- this unfortunately does not seem to have resolved the issue. I am still encountering it (using desktop app)
Gayani_S
Mar 6, 2024 11:29 AM UTC
Hey @Kendall_Van_Horne, thanks for updating me on this! I’ve just created a support ticket on your behalf, so our technical quality team can investigate further what’s causing this. Your ticket number is #941211, for reference. Please also share your file link with our team with support-share@figma.com invited directly as an editor (this won’t affect your billing at all).
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Thank you,
Gayani
Alina_Brender
Mar 7, 2024 8:59 AM UTC
I have the same issue. Nothing happens when I click restore component conection
Gayani_S
Mar 8, 2024 9:48 AM UTC
Hey @Alina_Brender, thank you for reaching out! I’ve seen that the case from Kendall is still ongoing, so I’ve just created a support ticket on your behalf. Your ticket number is #943295, for reference. Please also share your file link with our team with support-share@figma.com invited directly as an editor (this won’t affect your billing at all).
Let me know if you have any further questions.
Thank you,
Gayani
johntk22
Mar 8, 2024 1:31 PM UTC
ensure that both the files are sync properly with the cloud storage because sometime issue with syncing can result the disconnect.
Alina_Brender
Mar 11, 2024 12:39 PM UTC
Thanls I have shared with u. I have put back all the components now. I need to work on the document. Library filed called data library.
Gayani_S
Mar 12, 2024 8:49 AM UTC
Hey @Alina_Brender, thanks for updating me! I checked your support ticket and did not see any file link, also I did not receive a DM from you. Can you let me know where you’ve shared it with me please ?
