Instance swapped icons do not receive color updates anymore
  • September 29, 2023
  • 32 replies
  • 3323 views
When changing an icon’s color in a button component, the color change doesn’t appear on the buttons where the icon has been instance swapped. This was still working yesterday, and I tested it on several projects with different icon sets.
September 29, 2023
I’ve noticed the same problem
Hi Laura, thank you for flagging this!
This definitely seems odd. Would you mind reaching out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new?
Be sure to use your Figma account email, share a short video recreating the issue, include the links to your file, and share it with support-share@figma.com so they can take a closer look. Thank you!
Andrey_G
October 18, 2023
I’ve got the same trouble today. This was still working always before.
Hey Andrey_G,
Thank you also for flagging this, and sorry for the trouble!
I saw in our back end that we have a similar bug that our engineering team is working on it (with color override not preserved after instance swap property swap). Is it also an issue that you encounter?
If not, can you please reach out to the support team with a video recording (and a copy of your file) of what’s happening on your end? This will help the team to investigate it further. Here the form to fill out: https://help.figma.com/hc/en-us/requests/new Thank you!
Andrey_G
October 19, 2023
Hi, Celine!
When changing an icon’s color in a parent component, the color change doesn’t appear on the child components where the icon has been instance swapped.
I filled out that form, and attached this explanation video.
Thank you!
Thank you for taking the time to record the video!
I saw your ticket in our back end and have escalated internally. Thank you for your patience in the meantime 🙏
Hi everyone,
For visibility, our technical team has checked internally. It’s the expected behavior that changes to a main component won’t be applied to instances that contain any overrides on that element (including fill or instance swaps) as there’s a risk it might clear those overrides.
We continue to flag with the engineers that may users do not find this intuitive so they can consider other options for the future.
Thank you everyone for reporting this!
Dan_Hopewell
December 5, 2023
While I can maybe understand it being expected behavior to not reset overrides that were set manually at the instance level, it seems intuitively not expected that this would be the case for overrides that were only set on a component itself.
I was just struggling with this issue while updating a component and, to make sure I wasn’t totally missing something, created a quick and clean test file for myself (to confirm that, for example, it wasn’t just caused by manual, instance-level overrides that I was overlooking).
For this test, I first created some well-structured icon components (i.e., with the same layer structure and layer names in each to inherit any color overrides applied to them):
Then I created a simple component with a nested icon component, applying color overrides at the component level and configuring an instance swap for changing the icon at the instance level:
I then drew out instances from this component, swapping in new icons. The color overrides applied on the component were, as expected, inherited by the new icons:
If I then, without making any other edits or applying any other overrides to these instances (outside of swapping the icons), go back to the component and change my blue (#2288CC) to a green (#336633) at the component level…
… this new color shows up as expected in the fills and strokes of all relevant instances, and as the color override for the original (placeholder) icon where it was never swapped. But any swapped icons remain the original blue:
To be clear: I only ever set colors on the component itself and never once touched the colors of the instances.
And when I first used the instance swap to select an icon, it inherited the component’s color override as expected.
But that color override was also apparently then locked in at the instance level, the instance ignoring the color set at the component level completely. Which can be reaffirmed by swapping the icon again and seeing it retain the blue color it originally inherited from its parent component (even when swapped back to the original icon):
This behavior seems broken to me on a very basic level
On the one hand, changing icons on instances of a component seems like an extremely common (maybe even the primary) use case for instance swaps.
At the same time, I also think it’s a baseline expectation of components that an edit to something like its color should apply globally to all instances (with the exception of manual overrides that have previously been made at the individual instance level).
So this current “expected behavior” breaks this core expectation and seemingly leaves any and all swapped icons permanently beyond the reach of their parent components, which seems entirely counter to the point of using components in the first place.
(Editing to add a view-only link to my test file if it’s useful for any reason.)
Dan_Hopewell
March 1, 2024
Following up on this again: @Celine_Figma can you confirm that the behavior I documented above is considered expected and desirable, rather than a bug or problem?
Not having changes at the component level apply to instances that utilize a swap on a nested instance seems to suggest that using instance swap properties in components at all can have the effect of fundamentally breaking them:
What am I missing about this?
Hey there! Thank you for the detail feedback.
Not sure how/why the icon retains in blue here, it would be great to have a quick video recording to see if we can replicate it.
Still as a reminder, it is expected if in the instance level, you swap the icon again and override in blue. Thus, as explained, even if you made changes to the main component, it won’t be applied to instances that contain any overrides on that element (including fill or instance swaps).
This has been flagged to our engineers as somewhat counterintuitive behavior so it may change in the future but at the moment, this isn’t a bug and expected behavior.
If it’s not the case, this may be unexpected. So, I’d recommend you to reach out directly to the support team with a copy of your file here, the technical specialist can investigate it further.
Be sure to use your Figma account email, share a short video recording when you encounter the issue, include a link to your file, and share it with support-share@figma.com as an Editor, so the team can have a look at it. Thank you!
