Regi
Apr 4, 2024 7:10 AM UTC
Instance swap double size?
I was wondering if there was a reason for size changes when searching for an instance swap (icon in this case) displays results that are 2x larger than when not searching. Is it a setting I’m missing?
Thanks
Without search: (regular size)
without search
With search: (double size)
Regi
RegiAuthor
Apr 4, 2024 7:48 AM UTC
It seems that if searching “Preferred” the size is ‘regular’ whereas searching a custom library scales the results (for components (nested only - need to double check this?) )…
Apr 8, 2024 1:13 AM UTC
Hi @Regi, Thank you for getting in touch about the instance menu. I see where your confusion is coming from.
I did some testing on my end, and it looks like when the view is Show as grid, the preview instance size in the instance menu is smaller when you select Preferred. However, if the view is Show as list, the preview size remains the same when you select Preferred.
If you want the preview size to stay consistent, please consider switching to the “Show as list” option.
I hope this helps clarify things a bit. Please let me know if I missed anything. Also, any input from our community is always appreciated!
Thanks!
