Martti Sirkkola
Jun 26, 2025 7:56 PM UTC
Inserting Component to a specific layer
This seems like a very basic question, but I wasn’t able to find an answer or a solution: when I’m inserting/adding a component from my assets, what’s the best way to make sure it goes directly in to the correct folder in my layers? Currently an inserted component always goes at the TOP of the layers - and then I need to scroll and drag it to where I want it.
Can anyone help? thanks
Junko3Solution
Jun 27, 2025 4:15 AM UTC
Hi ​@Martti Sirkkola,
I understand you're looking for a way to control where your inserted components land in the Layers panel, instead of them always jumping to the top.
Could you try inserting assets using the Actions menu in the toolbar? Here's how:
  1. Select the layer where you want to insert your component.
  2. Click “Actions” icon in the toolbar, then open the “Asset” tab.
  3. Select the component you want to insert, then click “Insert”.
Here's a quick video:
Hope it helps!
Junko3Solution
Hope it helps!
Martti Sirkkola
Jun 30, 2025 10:13 AM UTC
Hi @junko3
Thank you! This solved my problem
all the best,
Martti
