P115
September 30, 2024
Insane PDF file size
  • September 30, 2024
  • 13 replies
  • 1643 views
I’m trying to export a single page in Figma into a PDF. Unfortunately it reaches file sizes between 320 MB and 370 MB depending on the export setting, making it useless as PDF readers struggle to even load it. Are there any common pitfalls to avoid? I don’t know any way to diagnose the issue so I’d maybe know which elements to remove.
Luke-Itineris
September 30, 2024
This is a common issue. I recommend exporting the frame as a JPG first, then converting it to a PDF using Adobe or an online tool.
Exporting directly to PDF in Figma often results in large file sizes—it’s not really optimized for PDF exports. Figma is better suited for design work than for creating PDFs.
P115
P115Author
September 30, 2024
Unfortunately that would turn all text on the document into an image as well, but I need the text to remain as text.
So the best idea I got so far is basically turning my document into two documents, one for the background design and one for the text. Then I could export the backgrounds into an image and put it back into Figma.
Nellya
Power Member
September 30, 2024
You can use some online tools like ilovepdf.com for compressing exported from Figma pdf
Luke-Itineris
September 30, 2024
I take it these PDFs will be printed? For print, we use InDesign.
P115
P115Author
September 30, 2024
That unfortunately requires sharing your data with some random online provider. How much compression would it yield? I’m guessing it won’t reduce the file size from 370 MB to <20 MB, which I need unfortunately.
Nellya
Power Member
September 30, 2024
You can try to download and use desktop app for compressing pdf, for example pdf24.org
Or try to export pdf from Figma with a plugins like Compressed PDF and Image Exporter
Luke-Itineris
October 10, 2024
Do you have Adobe? If so, use Acrobat to reduce the file size.
If not, use a compressor like here. Upload the exported JPGs/PNGs and then reimport them into your Figma frames.
P115
P115Author
October 10, 2024
Tried that, unfortunately the compression is not nearly enough if Figma produces such absurdly unusable sizes. I’m now 10+ hours deep into attempts to fix this and I find it truly absurd that there are 5 years old threads talking about the same issue and it’s still not fixed. In my case the PDF export feature is literally bait that got me to waste 50+ hours on designing in Figma for the first time while the final product is not usable so far.
Luke-Itineris
October 10, 2024
Afraid PDF’s are a natural export for Figma, they shouldn’t even offer it.
You can always share the file with me privately and I can help.
Osama_Turki
October 10, 2024
You can use ilovepdf.com to compress the file and reduce its size from 370mb to less than 10 mb, also you can use different plugins to export Figma to PDF such as TinyImage compressor - which will export it in a reduced size of about 80%-90% less.
