Yulia
May 11, 2021 10:42 AM UTC
In prototype mode, the hover effect ("while hovering") sticks and does not disappear
In prototype mode, the hover effect (“while hovering”) sticks and does not disappear after hovering over an element. As a result, when hovering over several objects, all hover effects remain on the screen. What is the bug? : worried:
Closing and reopening the prototype helps solve the problem.
But after some time, the bug may appear again.
It looks like some kind of memory problem, in general, prototypes and files take a long time to load and sometimes slow down. It’s very unpleasant to work. In Figma via macOS app
Joshua_Davis
Mar 18, 2024 7:35 PM UTC
Just ran into this issue. To see it’s been an issue for this long is disconcerting. Does anyone know if this goes away if you use the prototype for site creation?
Uqualo
Mar 25, 2024 3:38 AM UTC
Alright, then what is the “while hovering” option for?
Jk, I get that many here just need their pt to work and these workarounds may get a good dose of appreciation. Kudos to those who provide them.
Allow me to rant for those of us who just want things to work the way they’re supposed to, though.
Uqualo
Mar 25, 2024 3:41 AM UTC
thanks, this worked for me.
Still quite annoying
Thomas_Fischer
Mar 28, 2024 4:54 PM UTC
Years into this thread. Still hopelessly broken.
At times, it seems to be related to nested components (which have always caused as many issues as they solve). However, even if you detach the parent level in nested components, they still seem to retain residual linkages that totally foul up the hover interaction.
Apr 10, 2024 10:12 AM UTC
Same issue here!
Until they fix it, the best workaround I’ve found is to close the prototype tab/window and open it again.
Victor_Paredes
Jun 7, 2024 8:29 PM UTC
Same issue. It’s really rough.
Leonardo_Falaschini
Jul 16, 2024 10:22 AM UTC
Figma doesn’t seem to fix any of these bugs, nor update the variables panel. Nothing. It’s like they don’t care and they have to put AI instead of making the UI and the prototyping work properly. (Shrugs)
kauheaa
Jul 25, 2024 3:27 PM UTC
worked fine so far, now stuck all the time. really annoying and difficult to work with.
Jul 25, 2024 3:38 PM UTC
Hey All, thanks for flagging this and apologies for the lack of acknowledgement here!
This topic was created 3 months before I joined Figma, and during that time, the forum was primarily run by the community.
If none of the suggested workarounds above fix the issue for you, your best option would be filing a bug report with support directly, as mentioned by @Fernando_Lins.
You can submit a bug report to our support team directly via the form here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Please use your Figma account email, include a link to the file, and share edit access with support-share@figma.com, so the team can take a closer look at how you’ve set up your prototype.
Kolodziej_Ashley
Sep 12, 2024 9:06 PM UTC
I am still experiencing this problem and have opened a support ticket with Figma as instructed above.
