Andrey24
Jun 20, 2026 8:11 AM UTC
In Figma Slides, I can’t resize the table.
When creating a table in Figma Slides, there’s one limitation: the table size is constrained. I can’t resize it to the exact proportions I need — for example, 10×20 pixels. Is that possible or not?
adamsmasher
adamsmasherSolution
Jun 21, 2026 4:48 PM UTC
Hey, ​@Andrey24! Thanks for your post - hopefully it hasn’t been too confusing trying to set up your table in slides.
What dimensions did you actually want to use with the table? You should be able to click and enter whatever dimensions you want, though there are some minimums for the width and height depending on the number of rows and cells (for example, a table with two rows and two cells is 128x176). As long as you are entering a width and height larger than the minimum, you can enter any sizes you need. Make sense?
adamsmasher
adamsmasherSolution
Andrey24
Andrey24Author
Jun 21, 2026 6:32 PM UTC
That’s exactly the issue — I actually want to make it even smaller because I need to fit a large number of rows, like 40–50. Is this something that’s expected to be supported in the future, or should I not count on it and just create those kinds of tables in PowerPoint or Excel instead?
adamsmasher
Jun 21, 2026 10:41 PM UTC
Thanks for clarifying, ​@Andrey24 - I can see why you’d want to do that if you’re looking to squeeze a large number of rows into the table.
There’s a minimum height for rows to maintain legibility and space for fonts. Given that a slide also has a finite height and width (unlike the canvas of Figma Design, for example), this means the table can only be so small before you hit that limit and make the contents of the table difficult to read in the slide. Maybe you could include a select number of rows in the table, then provide a link to view a Google sheet or download an excel file?
Andrey24
Andrey24Author
Jun 22, 2026 4:47 AM UTC
Unfortunately, that probably won’t be possible, since the slide is meant to be displayed on a large screen for a large audience.
