details_wes
May 18, 2022 7:24 AM UTC
Images with 300 DPI resolution
Can we export the images with 300 DPI in FIGMA, I tried but did not found any solution.
bruja_la
Oct 1, 2024 5:13 AM UTC
i made this small code you can just modify the values, click run to calculate cm to px:
Dart cmToPixels 300dpi
Patrick Hennessey
Mar 21, 2025 5:55 PM UTC
​@Abha_K Multiply all your inches by a value of 100, then when you export for 600dpi, choose 6x.
For example, if you had a 4x5 inch design and you wanted to produce a 300 dpi asset for that size, make a canvas that is 400x500px. Then when you export, choose 3x to get 300 dpi.
Make sense?
Yuka17
Apr 30, 2025 5:30 AM UTC
I asked Chat GPT and figured out 4.17x method too, but it made slight line on the outer frame. It said I need to do with an integer. I did with 5x and it’s gone. I’m not sure anyone needs this information but just in case...
