Hey @hb.lee, sorry for the trouble!
Figma only downloads high quality (larger than 512 by 512 pixels) versions of images in your current viewport. For images outside your current view, Figma loads a lower quality version to improve performance when you first load a file.
Because of this, when you have a lot of high-resolution images in a file, your images may look blurry at first then will load the high-resolution images as you continue to explore the file.
To help speed things up, you can try the following:
- Close and reopen the affected file
- Close any other Figma files you have open
- Check your internet speed and connection to make sure your device is online
- Using Figma in the browser: quit your internet browser application, then relaunch it.
- Using the desktop app: right-click on the file’s tab and select Reload Tab.
