melinda811
Mar 10, 2025 10:35 PM UTC
Icons suddenly are not visible in frame.
See video: https://drive.google.com/file/d/1q2l_K3N8R9grxH-dpBxkcROjJICCa0JI/view?usp=sharing
I’m using the Material Symbols plug-in to put together some icons and suddenly the last handful of them have disappeared visually. The components are still there, as I can see it them in the layers panel as well as click/drag on the invisible group of it. Adjusting the icon’s parameters in the right panel doesn’t do anything. Even moving i off the frame doesn’t do anything. I have  tried refreshing the app, the browser, and even restarted my entire system.
What’s going on?? Is this a plugin issue?
Mar 11, 2025 5:10 AM UTC
Hi  ​@melinda811
Thanks for reaching out. That sounds strange—I tried to replicate the behavior but couldn’t.
Could you try “regenerate all instances (slow)” via Actions? This action basically re-clicks on all instances, and it sometimes helps bring back missing objects.
If the issue persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Please make sure you use the email associated with your Figma account, include links to the file in question, and share access with support-share@figma.com. Don't worry, inviting us to view your file won't impact your billing.
Thanks for your patience!
Toku
melinda811
Mar 11, 2025 5:34 PM UTC
Hi ​@y_toku ! Thank you for your response.
I tried that, and did not see any change :( I ended up just deleting those objects and regenerating them through the plugin. If the issue occurs again, I’ll reach out to the support team.
