May 15, 2023 10:05 PM UTC
Icon swap preferred option constantly appearing
Hi I am encountering situation where when I try to swap the icon from the ones linked to the styleguide, it appears with ‘Preferred’ instead of the icon’s linked styleguide. Is there way avoid seeing the preferred icons at all? (I.e, the icon I am trying to swap is from the same styleguide to the one I wish to swap. The icon is component already linked to the styleguide).
Agustin_Posse
May 17, 2023 5:37 PM UTC
Hi! to avoid seeing preferred values you will need to remove the default preferred value that is shown when creating the instance swap property. (see the “minus” button below, it appears when hovering)
In case you do want preferred values, you can add them with the “plus” icon (just above the “minus” button)
May 24, 2024 9:54 AM UTC
Hey, Im having the same problem. Is there a way to edit the property already created or you need to create a new one?
May 27, 2024 3:49 PM UTC
