Hey there, thanks for reaching out!
Can you double-check that your content is entirely inside your frame horizontally? If anything is overflowing beyond the boundaries of the frame, it can sometimes cause unintended scrolling.
After checking for horizontal overflow, select the frame in Figma then ensure the Prototype tab > Scroll behavior to see if the overflow property is set to Vertical rather than Horizontal or Both directions. Hope this helps!
