Ruoti Jacopo
Oct 29, 2026 11:02 AM UTC
How to Send a Frame Directly to Figma Make
Hi, after the latest update, “Send to Figma Make” seems to have been replaced by “Build with code.”
How can I send a frame directly to Figma Make without copying and pasting it manually?
Thanks for your support!
reboltalloy
Oct 29, 2026 11:06 AM UTC
According to Figma’s current help documentation, you can select a frame in Figma Design, choose Code from the toolbar (or press B), and click Build selection in the right sidebar to turn it into a code layer. This is a documented alternative, although it may not be the same workflow as the former direct-to-Make action.
Help Center+1
You can also check Figma’s guide: Code layers in Figma Design.
Ruoti Jacopo
Oct 29, 2026 11:15 AM UTC
Thanks for your support! What if I don’t want to create a code layer? Is there still a way to send a frame directly to Figma Make, like with the previous “Send to Figma Make” option?
