Afif hanifudin
Aug 26, 2025 6:46 PM UTC
How to Quickly Change the Same Font but only on a few pages
I want to change all the fonts, but I currently have thousands of pages, and my device can't handle the current feature. Is there a solution that only changes the fonts on a few pages?
ProUser1
Aug 26, 2025 8:00 PM UTC
Hi ​@Afif hanifudin
Yes — you don’t need to run a global “Replace Fonts” across the whole file if your machine is choking on thousands of pages. In Figma there are a few more targeted approaches you can use to only change fonts on a few pages:
🔹 1. Use the Selection/Current Page Replace
Instead of File → Replace Fonts (which scans the whole doc):
  • Go to the page you want to update.
  • Select the frames/text layers you want (Ctrl/Cmd + A will select everything on that page).
  • In the right-hand Text panel, you can change the font — it applies only to selected text.
  • If you have nested frames/components, run Edit → Select All with Same Font to grab them more easily.
🔹 2. Use the Search/Find & Replace (limited scope)
  • Press Ctrl/Cmd + F to open Search.
  • Search for a font name (e.g., Roboto).
  • Scope the search to “This Page” instead of “Entire File.”
  • Replace it with your new font.
🔹 3. Rely on Text Styles (if set up)
If your file uses Text Styles (e.g., “Body,” “Heading”), updating the style once will update every instance that uses it — and you can update just the styles used on certain pages.
🔹 4. Use a Plugin for page-level replacement
Some plugins let you replace fonts only on selected frames or pages (e.g. “Batch Styler” or “Font Replacer”).
Steps:
  • Install plugin → select just the frames or page → run replacement.
    This avoids scanning thousands of pages at once.
🔹 5. Duplicate & Split Workload
If performance is a big issue, you can:
  • Duplicate the file.
  • Delete all but the few pages you need in the duplicate.
  • Run “Replace Fonts” there.
  • Copy the updated pages back into the main file.
