Chaitanya_Rajguru
Aug 19, 2024 12:53 PM UTC
How to make async call to the figma.getNodeByIdAsync() function?
Greetings from a newbie!
I cannot get a call to Figma.getNodeByIdAsync() to work. Could anyone please tell me what I am doing wrong? I have searched this forum and referred to a sample plugin go-to that uses this function, but I am still stuck.
Below is my simplified code just for checking this functionality. When I run it as part of the plugin, console logs #1 and #2 are generated but not #3, and the console returns to the ‘>’ prompt.
Thank you!
Figma_plugin_issue
Pavel_Kiselev
Power Member
Aug 20, 2024 5:52 AM UTC
To make it work you need to run it async way. Just wrap your code into another asynchronous function and run getParent with await keyword
(async ()=> {
    await getParen(id);
    figma.closePlugin();
tank666
Aug 19, 2024 2:35 PM UTC
Is there a call to figma.closePlugin() after the 100th line?
Chaitanya_Rajguru
Aug 19, 2024 5:04 PM UTC
Thanks, yes, there is. (I have some commented-out code sitting around, so I didn’t post the full program.)
tank666
Aug 19, 2024 7:47 PM UTC
The commented lines should not affect further execution of the code. Make sure that figma.closePlugin() is called only after the promise is completed or try deleting/commenting everything except what is in the screenshot and compiling the code.
Chaitanya_Rajguru
Aug 20, 2024 5:36 AM UTC
Thank you, @tank666. I cleaned up the file so it contains only the below code. I added one console.log to be doubly sure. I still have the same issue: I get console logs #1, #2, #3, but #4 is skipped. (I can get the demo plugin to work, though that does not have any async calls. I am trying to get the go-to plugin to work now.)
Figma_plugin_issue2
Pavel_Kiselev
Power Member
(async ()=> {
    await getParen(id);
Chaitanya_Rajguru
Aug 20, 2024 7:38 AM UTC
Thank you, @Pavel_Kiselev . I tried this and added some null checks with a renamed function that does the same thing. However, still no luck, I get only console logs #1, #2, #3 but not #4. What else could be the reason?
Pavel_Kiselev
Power Member
Aug 20, 2024 9:48 AM UTC
No idea. There is something not very obvious. Debugging to the rescue.
Chaitanya_Rajguru
Aug 20, 2024 10:31 AM UTC
Yes, surely. Thank you for looking into it.
tank666
Aug 20, 2024 5:17 PM UTC
The code from this screenshot should work correctly, and you should see 1, 2, 3 and 4a in the console. And 4b will never appear because the else block will never be executed. Check the compiled js file to make sure it matches your ts file.
Chaitanya_Rajguru
Aug 21, 2024 4:36 AM UTC
Ok, thank you @tank666. The JavaScript code looks ok to me, but I need to debug deeper.
