Iuri_Fazli
Feb 8, 2023 11:19 AM UTC
How to export assets via plugin api?
Hi to all, is it possible to export assets from figma like images, svg?. I need a zip archieve of this files. thanks!
Power Member
Feb 8, 2023 11:23 AM UTC
Have you tried searching for existing solutions and plugins API documentation?
Josh_Kulpa
Feb 26, 2025 9:52 PM UTC
I certainly have, and I am no closer to determining how to make this work. What’s worse, is that the plugin API fails completely silently - I can’t even get it to throw errors with extensive error checking.
Do you have any actual solutions, or are you just going to give another glib response?
tank666
Mar 2, 2025 4:30 PM UTC
​@Josh_Kulpa, what kind of help do you want? It's not clear from your description what you did. If you provide enough information, including the code you're using/wrote, you'll be more likely to get a concrete answer. And on topic, to export nodes use the exportAsync method, and to pack them into a ZIP archive you can use a library like JSZip.
Josh_Kulpa
Mar 5, 2025 1:57 PM UTC
I would like a functioning code example of how to export a frame as .svg and/or .pdf using the plugin API.
Currently, there is no such code example anywhere I can find - not the documentation, not in the community, and not anywhere else.
Here’s the code I put into my test plugin. Any help would be immensely appreciated:
const axios = require('axios')
const { performance } = require('perf_hooks')
const fs = require('fs')
const blobStream = require('blob-stream');
const PDFDocument = require('pdfkit')
const SVGtoPDF = require('svg-to-pdfkit');
let axiosInstance = axios.create({
baseURL: "https://api.figma.com/v1/",
headers: {
"X-Figma-Token": process.env.ACCESS_TOKEN
const pdfCreator = {
async getFilePages(key) {
let start = performance.now()
let response = await axiosInstance.get(`files/${key}`)
let end = performance.now()
console.log(`Got file pages in ${end - start} ms`)
return this.sortFrames(response.data.document.children[0].children
.filter(layer => layer.type === "FRAME"))
sortFrames(pages) {
let lines = []
let sortedByHeight = pages.sort((a, b) => a.absoluteBoundingBox.y - b.absoluteBoundingBox.y)
let finalArray = []
for (let page in sortedByHeight) {
let pageItem = sortedByHeight[page]
let nextPageItem = sortedByHeight[parseInt(page) + 1]
if (nextPageItem) {
let seuil = pageItem.absoluteBoundingBox.height / 2
if (Math.abs(nextPageItem.absoluteBoundingBox.y - pageItem.absoluteBoundingBox.y) <= seuil) {
if (lines.length == 0) {
lines.push(pageItem)
lines.push(nextPageItem)
} else {
if (lines.length > 0) {
let index = sortedByHeight.findIndex((el) => { return el.id === lines[0].id })
let sortedLine = lines.sort((a, b) => a.absoluteBoundingBox.x - b.absoluteBoundingBox.x)
sortedByHeight.splice(index, lines.length)
sortedByHeight.splice(index, 0, ...lines);
lines = []
return sortedByHeight
async exportPages(pages, key) {
let response = await axiosInstance.get(`images/${key}`, {
params: {
ids: pages.map(page => page.id).join(','),
format: "svg"
for (let page of pages) {
page.imageUrl = response.data.images[page.id]
return "ok"
async getImagesContent(pages) {
let imagesPromises = []
let imagePromise = this.getImageContent(page)
imagesPromises.push(imagePromise)
await Promise.all(imagesPromises)
console.log(`Got images content in ${end - start} ms `)
return "ok"
async getImageContent(page) {
let response = await axios.get(page.imageUrl)
page.svgContent = response.data
return "content"
async createPdf(pages, res) {
const options = {
assumePt: true
let doc = new PDFDocument({ compress: false, size: [pages[0].absoluteBoundingBox.width, pages[0].absoluteBoundingBox.height] })
let stream = doc.pipe(res);
SVGtoPDF(doc, pages[0].svgContent, 0, 0, options);
pages.shift()
doc.addPage({ size: [page.absoluteBoundingBox.width, page.absoluteBoundingBox.height] })
SVGtoPDF(doc, page.svgContent, 0, 0, options);
doc.end();
module.exports = pdfCreator
tank666
Mar 9, 2025 6:28 PM UTC
​@Josh_Kulpa, are you sure you need to use the Plugin API? From the code you provided, I see that you used the REST API endpoints.
It's really weird that you didn't find any code examples for exporting nodes anywhere, because I found everything on GitHub. Here are some:
Josh_Kulpa
Mar 12, 2025 1:27 PM UTC
export interface ExportableBytes {
setting: ExportSettingsImage | ExportSettingsPDF | ExportSettingsSVG;
bytes: Uint8Array;
async function main(nodes): Promise<string> {
if (!hasValidSelection(selection)) return Promise.resolve("Nothing selected for export")
let exportableBytes: ExportableBytes[] = []
for (let node of nodes) {
let { name, exportSettings } = node
if (exportSettings.length === 0) {
exportSettings = [{ format: "PNG", suffix: '', constraint: { type: "SCALE", value: 1 }, contentsOnly: true }]
> let {name, exportsettings } = node
Does this code mean that the export settings have to be provided by the user in the GUI, rather than setting them programatically?
tank666
Mar 20, 2025 9:03 PM UTC
​@Josh_Kulpa, the code above takes the exportSettings array as a basis, and it does not matter whether it is added manually by the user in the Figma UI or using the API. Also in your code snippet you can see a block with a condition, where an array with one element of the export settings is programmatically added if the length of this array is 0. But for export it is not necessary to add/modify the exportSettings array, just use the previously mentioned exportAsync method with the settings you need.
