Sannah_Siddique
Jun 10, 2022 3:17 AM UTC
How to create a scrolling section over a fixed section?
Hi!
I’m new to Figma & design - but trying to create an interaction on a prototype which involves two sections on one frame. One section would be fixed and is the top part of the frame, whilst the second section would allow me to scroll over the first section.
A reference of the same interaction can be found here on mobile view: [The Classic Check Cashmere Scarf in Mid Camel | Burberry® Official]
Sadly when I fix position when scrolling of the the top section of the frame, and set the second section to vertical scrolling it will scroll underneath the top section which is fixed on scroll.
Any help or advice would be greatly appreciated.
Philip9
Jun 27, 2022 1:33 PM UTC
Have you found a solution for this?
Phil_Larsen
Jun 27, 2022 7:36 PM UTC
When setting a layer to Fix Position When Scrolling, the layer will be above all other scrolling elements making any scrolling content appear beneath.
I created two variations on how you can get a result that might be more of what you’re looking for.
Here is a draft file you can see the difference:
Figma – 27 Jun 22
Melissa15
Dec 6, 2022 8:31 PM UTC
This is super helpful! Do you think the nested approach could be achieved with three cards?
hubblebot
Jan 8, 2023 10:04 PM UTC
@Phil_Larsen 's solution is super helpful, but what about use cases where you want there to be scrolling content both above and below a fixed element, without 2 different scrolling frames?
Modifying the order of fixed elements is easy enough via z-index and position:relative in code — I’m a little confused as to why Figma opted to set all the fixed layers forcefully at the top in the first place. Curious if there’s an existing feature request addressing this issue.
John_Kennedy_Saguban
Jan 10, 2023 2:23 AM UTC
This works if the “fixed” frame is just a plain color or image. But once you have buttons, text and anything else, when you toggle “fix position” it tends to be placed above everything else, so incoming frames from below when scrolling for example, those elements on the fixed frame shows in from of the incoming frame. I still can’t find solution for this one
Jarek_Marciniak
Jan 19, 2023 9:35 AM UTC
I’m joining the question. I don’t understand why fixed elements are forced to be above everything else. Doesn’t make any sense.
Feb 24, 2023 9:09 AM UTC
Hey guys, I’m from Taiwan. I think I find the way to resolve this issue.
In “Layer and Prototype Settings” video, you can check the relationships between all frames or other items.
In “Figma Prototype” video, yep! You’ll see the prototype that I made, and a shortcoming too 😂
Hope it’s helpful. And forgiving me for my poor English 😅
May 11, 2023 1:36 AM UTC
Hi! Did you find a solution for this? I tried to do that but I didnt find any tutorial or solution
May 11, 2023 1:37 AM UTC
Aug 10, 2023 9:07 AM UTC
It seems that you can do this now - Just set the layer to sticky, and it will stick based on the hierarchy the layer is in.
