AbhishekChavanFromSatara
How to Access MCP OAuth Scope (mcp:connect)?
  • February 6, 2026
  • 25 replies
  • 3957 views
Hi Figma Community!
I'm working on a design-to-code automation tool and would like to integrate with Figma's Model Context Protocol (MCP) endpoint.
The Issue
When requesting the mcp:connect scope during OAuth authorization, I receive:
"error": true,
"status": 400,
"message": "Invalid scopes for app"
OAuth App Details:
Questions
  1. Is the mcp:connect scope available for third-party OAuth apps?
  2. If restricted, is there a beta program or application process?
  3. Is this scope only available to official Figma extensions (VS Code, Cursor)?
What I've Tried
  •  Standard OAuth flow works fine with public scopes
  •  Got valid Bearer token
  •  MCP endpoint (https://mcp.figma.com/mcp) returns 401 with www-authenticate: Bearer scope="mcp:connect"
Best answer by Celyn_L
Hi everyone, thanks for chiming in here.
We really appreciate you taking the time to share how this impacts your workflows. To help us capture your feedback in more detail, the best next step will be to reach out to your account representative or contact Support and include:
  • Which tool(s) you'd like to connect with Figma
  • How you'd expect those tools to work with Figma's MCP Server
  • The specific workflows or outcomes this would enable for you or your team
The more details you can provide, the better we can understand your use case and ensure your feedback reaches the right teams. I've also shared the feedback from everyone in this thread with the team. Thanks again for taking the time to share your thoughts! 🙏
sheetal mohite
Facing the similar issue for similar requirement.
trikohung-first-cognition
I’m facing the same issue trying to connect to Figma MCP via Github Copilot on Webstorms on Arch Linux
Zack Rossman
I’m seeing the same issue
Dominik_Wawrzonek
Same for me. Is even possible to reach mcp with OAuth and Bearer token ?
Chase Reasoner
Same issue here. looks like they have locked down mcp connection to specific AI clients that support the DCR process. so you can’t proxy or use a gateway.
Celyn_L
Hi ​@AbhishekChavanFromSatara and others following along — Celyn from Figma Community Support here.
Thanks everyone for flagging this and for sharing the detailed context around the MCP OAuth flow and mcp:connect scope, that’s really helpful.
I’ve raised this with our internal team so they can take a closer look at what might be happening here, including the questions around scope availability and supported clients.
I’ll follow up here as soon as I have more insights to share.
Appreciate your patience in the meantime 🙏
Celyn_L
Hi everyone — thank you so much for your patience here, really appreciate it.
I've checked with the team, and confirmed that this is expected behavior.
At the moment, the mcp:connect scope isn't available for general third-party OAuth apps — MCP access is currently limited to supported clients and integrations.
We're being intentional about the integrations we support in the near term, and will continue evaluating additional clients as our approach to MCP evolves.
In the meantime, you can join the waitlist here: https://www.figma.com/mcp-catalog/
Thanks again for taking the time to raise this here 🙌
Nitish Kumar Pilla
​@Celyn_L  We’re trying to connect Figma’s official remote MCP server to AWS Bedrock AgentCore Gateway for an internal enterprise AI workflow.
We can discover the MCP/OAuth metadata correctly, but dynamic client registration to https://api.figma.com/v1/oauth/mcp/register returns 403 Forbidden, and existing Figma PAT/service-token auth is rejected by https://mcp.figma.com/mcp because it requires the mcp:connect OAuth scope.
Our use case is not a public MCP client or IDE plugin. It is a secured internal gateway that already handles Auth0 user authentication and routes to Jira, GitHub, Lucid, and Figma tools. We would like to use the official Figma MCP instead of maintaining a REST-based workaround.
Is there a supported path for enterprise/internal AgentCore gateways to obtain an approved mcp:connect OAuth client, or to register an internal/private MCP client that is not listed publicly in the Figma MCP Catalog?
Celyn_L
Hi ​@Nitish Kumar Pilla - thanks for sharing all of this context, appreciate the detailed write-up.
I understand you’re trying to connect Figma’s official remote MCP server to an internal AWS Bedrock AgentCore Gateway workflow, and are currently blocked by the OAuth/client registration requirements around the mcp:connect scope for a private/internal client setup.
I’m checking with the team internally on this, and I’ll get back to you as soon as I have more information to share.
Appreciate your patience in the meanwhile.
