Adrian_Martell
Oct 15, 2024 12:52 PM UTC
How should I design my file to make it easer for Devs to export images and assets?
My development team has an issue where they are unable to export a frame that has a image as a fill, more specifically when that frame has other elements, like text or icons on top of that image. How should I set up my frames so that the background image and the text that are overlayed on top are not exported together as one?
Haroll
Figma Ambassador
Figma Ambassador
Oct 18, 2024 6:15 AM UTC
Hi @Adrian_Martell
Whenever you have a component you want to share with your developer and need to export it:
  1. Add an export settings by clicking the [+] button in the Export section.
  2. In the Fill section, you’ll notice a checkbox that is already checked
  3. Now, switch to Dev Mode on your frame. In the Assets section, hover over an item in the list. A download dropdown button will appear on the right. Clicking it will bring up a menu where you can choose to download either the entire frame (Layer export) or just the image used as the background (Source image file).
Hope it helped
Figma’s Forum Ambassador
