How do I Coby 1 "Go to main component"
  • May 29, 2024
  • 98 views
CS2
For example, I have finished working on the A file. I now need to design a B file, which is a completely different project from A. They have different UI styles, but they have tons of the same layout. So I copy a lot of components to the B folder, but I find that when I try to change the UI style, it comes up with “Go to main component” and then I’m back to the A folder instead of the components in my B folder.
ksn
  • May 30, 2024
Hey @CS2 - wanna make sure I understand:
For designing in file B – it has the same layout, but it should have completely different styles. Would you want a completely separate library with styles specifically for file B?
Was it a straight copy + paste of the design in file A into file B? Or did you duplicate file A and turn that into file B?
Not sure if that made sense from me, so apologies if that’s confusing. If you could clarify a bit more, that would be helpful.
