How can I publish component set (eg. component set of button with different state type and size) I do have few component set in my file and not able to publish the same from the design system
  • May 3, 2024
  • 4 replies
  • 193 views
How can I publish component set (eg. component set of button with different state type and size) I do have few component set in my file and not able to publish the same from the design system.
  • Figmate
  • May 6, 2024
Hi @Smruti_Tiwari2, Thanks for reaching out about publish a library! I understand your concern.
Just to clarify, libraries are only available on paid plans.
If you are on the free Starter plan, you won’t be able to publish them to access them in other files, but you can still create and use component sets. You can find more details here: Publish a library
If you are on a paid plan and have edit access on the library file, could you please try republishing to see if it resolves the issue?
Republishing steps:
  1. Go to library file and make a small change to the main component set, like adding a discription.
  2. Publish this change
  3. Go to the file with the linking issue and accept the update
If you encounter an error message during the publish, this article might assist you for troubleshooting: Adjust your network settings
If none of this information helps, I recommend reaching out directly to our support team through this link: https://help.figma.com/hc/en-us/requests/new
To assist our support team investigate, kindly provide the following information:
  1. Please ensure you use your Figma account email address.
  2. Share file links and add support-share@figma.com as an Editor to those files (this won’t impact your billing)
I hope this information is helpful. If I missed anything, please feel free to let us know. Also, if anyone from our community has additional suggestions, please feel free to share them here!
  • May 6, 2024
Check if you have errors in the variant set. You can’t publish sets with errors.
Hey Thank you there were some errors and once I corrected it, I was able to publish the same
Thank you, It helped
