Jan_Rehak
Feb 18, 2022 11:24 AM UTC
How can I merge two color styles in my style library?
Hello community,
I need to update the color styles library. I’d like to merge two color styles into one in order to update all the linking components to one new color. Is this even possible?
Thank you.
Antoine
Feb 24, 2022 11:06 AM UTC
I’m also looking for a way to merge styles. In my case text styles but it’s the same question.
Erling
Mar 24, 2022 9:04 AM UTC
I’m pretty sure I’ve done this before by just renaming one of the styles to the same as the other… But in that case it doesn’t work anymore.
Not that that was a good solution anyways, as it could lead to unintentional changes, especially when restructuring styles in groups. So I’d rather want to select two styles, right click and merge.
Maybe anyone knows of a plugin that can do this? If not, I guess the best way is to make the two styles you want to merge the same color, delete one and use the Style Organizer plugin to scan the page. Then you only have to click one button in the plugin to attach unlinked styles to the style. However, if the styles reside in a library, you have to go through every file and run the plugin…
Ivancis
Mar 25, 2022 6:18 PM UTC
Having it in separated library and "Merge libraries helps. But only when they are under the same name, AFAIK
Apr 17, 2023 7:42 PM UTC
What if the library that I want to merge out of doesn’t exist (no original library file), is there a way to do that without merging all the colors manually? The names are already the same.
Carioca_Andre
May 2, 2023 7:30 AM UTC
Any solutions yet? im also looking for a way to do this
Amrit_Shahi
May 24, 2023 6:15 AM UTC
I am also looking for this.
Nader
Jun 19, 2023 4:30 PM UTC
Ash.Sharifi
Jul 5, 2023 7:58 AM UTC
Same issue!
Joey_Brennan
Jul 10, 2023 9:02 PM UTC
+1 Need This!
Dan_Peterson
Aug 8, 2023 4:09 PM UTC
Looking for this as well!
