Julien_Dedale
Jun 15, 2026 10:53 AM UTC
How can I disable AI features? All of them.
Hello,
I’m a designer, I don’t need AI doing my work and nagging me constantly in the interface. It doesn’t work, it’s useless and I don’t want it.
It’s relentlessly pushed in the interface at each update, more and more aggressively (i just had to disable AI agent on the canvas for being bale to work) .
I don’t want any of these “features”.
What can I do?
Note: I already disabled the AI training.
Jun 15, 2026 2:31 PM UTC
Hi there, thanks for sharing your feedback! I understand you'd prefer not to use AI features and would like a way to completely disable them.
At the moment, we don't currently have an in-product setting that allows users to fully disable all AI features across Figma. (AI features cannot be disabled once they've been enabled for the team. Once AI features are turned on, they're permanently enabled on your account).
The Content training setting is separate and only controls whether content can be used to train Figma's AI model. It doesn't affect access to AI features.
If you're part of an Enterprise organization, organization admins may have access to additional AI controls at the organization level.
You can find more information here: Manage AI settings and content training for your team or organization
If you're unsure whether AI settings have been configured at the organization level for your account, please reach out to our Support team and they'll be happy to take a closer look. To do that, go to the Support Hub / Type “Disable ai features, contact agent” / Click Start a chat and select Enter , then follow the prompts.Thanks!
Julien_Dedale
Jun 15, 2026 3:01 PM UTC
OK thank you. I never turned on any AI feature, but the design agent was all over my design nonetheless so I guess it was activated automatically.
I contacted the support.
thx.
Todd Padwick
Jun 29, 2026 2:49 PM UTC
Im having the same problem. was presenting some work today after updating figma, and now an AI assistant voice started speaking for no reason.  I couldnt find any way to turn it off.
I’ve also noticed the ‘agents’ feature that shows a dotted blue line around elements ends up making changes without permission. This is terrible. I too want to remove all AI from my Figma interface as its slowing me down.
Tom Reem
Jun 30, 2026 7:02 PM UTC
Hey ​@Todd Padwick, thanks for reporting this. I have a few follow-up questions to better understand what happened.
Regarding the voice issue, can you provide more details on what the voice was doing? For example, was it reading content aloud, giving spoken instructions, or something else? There is no text-to-speech or audio output feature in Figma's agent, so this is worth looking into further. If you were presenting on a Mac, it's also worth checking whether Siri may have activated — this can happen system-wide, regardless of which app is open. You can check by going to System Settings → Apple Intelligence & Siri → Siri Requests → confirm "Listen for" is turned off.
For the unexpected changes in the file, please reply with the following:
  1. The steps leading up to the unexpected behavior, or more details on what you were doing right before you noticed the changes.
  2. Whether anyone else was working in the file at the same time or if they had edit access.
  3. Whether you're using Figma Design on a supported browser or, if using the Figma Desktop App, that it's version 126.6.11 or later.
If you'd like to hide the agent from your canvas while we sort this out, go to the main Figma menu in the upper left → Preferences → uncheck "Show Agents on Canvas".
Please share those details and I'll make sure your report reaches the right team. 🙏🏻
Ruth Gwilt
Oct 27, 2026 1:15 PM UTC
The interface for AI agent inputs is really poor as it’s so hard to get out of it when you’ve enabled it automatically.
Nobody wanted all this AI crap. Your time would have been better spent fixing the real user issues which have thousands of issues and votes but are ignored for years on end.
DefinitelyNotASpy
Oct 27, 2026 7:09 PM UTC
Absolute priority.  Top item on your sprint board.  Global AI OFF SWITCH!!.  Stop working on ALL OTHER FEATURES.  If you can’t do that, then you would really work on a great export to Sketch feature.
Daniel H.
Oct 28, 2026 7:02 PM UTC
A prime example of enshitification. Let us get rid of the AI. Generate content AI si so dumb and once enabled the context menus “ask for change” is impossible to get rid of. The escape key does not work. I’m rage quitting this application right now!
Van Snow
Nov 11, 2026 2:04 PM UTC
And I thought Figma was unusable before. Way to raise the bar. This AI garbage is the last straw for me, I’ll never open this app again. It has to be intentional, a conscious decision to make the product as frustrating and annoying as possible, it must serve you in some way, to have users constantly on edge. I’m not sure yet how that benefits you, but I can’t think of any other possible explanation for how every single change makes the product worse. It’s like you’re going for a Stockholm Syndrome based customer retention model.
z11h1111h
Nov 16, 2026 1:30 AM UTC
at the very least please move the ‘agents’ button when scaling/interacting with elements. scaling up muscle memory is mostly done from bottom right anchor and I’m tired of accidentally clicking it. I know that’s exactly why it’s there to encourage use, but I don’t think trying to trick users into engaging with it because they accidentally click it is great for convincing users.
Bev_Anderson
Nov 19, 2026 4:35 PM UTC
Just now, for no apparent reason, AI bubbles with a microphone icon started popping up in one of my files. There was no way to escape or close the popup(s). I clicked on something else, and the AI popup showed for that item. There needs to be a way to exit these things - there was absolutely no reason for it to show up in the first place. Stop doing stuff like this, please.
