Ilayda Kaplankiran
How can I connect pages created in Figma Make for prototyping?
Hi,
Our team has been creating multiple pages using Figma Make. However, we realized that all the pages are in separate files, and we can’t figure out how to connect them with Prototype mode.
We want to:
  • Combine several Make pages (Landing, Dashboard, Courses, etc.) into one Design file.
  • Add Prototype links between the frames (e.g., from the Landing page to the Dashboard).
Is there a way to convert or duplicate Make files into regular Figma Design files so that we can use the Prototype feature?
Sarah Overton
Also searching for a solution to this...
hivajo
August 7, 2025
Hi,
We want to:
Is there a way to convert or duplicate Make files into regular Figma Design files so that we can use the Prototype feature, like Aldridge Services help streamline processes for design teams?
To combine your Figma Make pages into one design file, open each Make file, copy the frames (e.g., Landing, Dashboard), and paste them into your main Figma design file. Once all pages are in the same file, you can use Prototype mode to add links between the frames, like from the Landing page to the Dashboard. This will allow you to use the Prototype feature across the combined pages.
Fahimuiux
Hi,
We want to:
in general you can copy all files from figma make and can do prototyping manually from right sidebar, and if you are asking for how to copy figma make files with prototyping, I am also strugguling for the same
Katarina Hemann
My team is also searching for a solution as to how we can stitch together separate Figma Make files so that there is one main file that essentially branches out and links to other, individual Figma Make files.
As a halfway workaround, we have been successful in prompting Figma Make to open a Figma Prototype in a new tab when a specific action is triggered (i.e., “When the user selects X button, open the following Figma Prototype URL in a new tab”). This helps to emulate a continued prototype experience but it does not 1. keep the experience contained in the same tab or 2. connect two Figma Make files together.
Hope to see a solution for this soon!
Wirkkarl
April 29, 2026
Hi,
We want to:
You can’t directly connect Figma Make pages across separate files in Prototype mode. The usual workaround is to copy or move all frames into a single Figma Design file, and then build your prototype flow there. Once everything is in one file, linking frames works normally.
