Bilal5
Aug 30, 2023 9:28 AM UTC
How are developers supposed to access variables?
I might be missing something essential here, but I can’t seem to figure out any way for developers (who have view-only, dev mode access) to actually view variables in a file/project/design system?
As far as I can see, they can only inspect single components. So they might see “button-primary-bg” for instance, and a corresponding hex color, in the dev mode side panel. But absolutely nowhere can they actually figure out what “button-primary-bg” is referring to (typically a color primitive, which again refers to a hex code). Not only is the alias not visible in the side panel, but the full list of variables is not accessible in dev mode either, as far as I can see.
I mean, it’s probably okay if you look at the design system as a static thing, where we could do a one-time export of all variables as a .json or something. But design systems are seldom static. New components are being created, and thus new aliases are needed quite often, specially in the early stages of a project. Am I crazy or is this a fairly big omission…?
Ognjen1
Jun 24, 2024 11:45 AM UTC
+1 We, as a team, are having same issue. Also, Devs can not switch between light and dark mode. That leave us with only one solution - to duplicate all design files and keeping two duplicate files relevant to changes is even greater pain
Liam_Morris1
Jun 27, 2024 2:40 PM UTC
Thank you for this!!
Zrinka_Z
Aug 2, 2024 4:16 PM UTC
Still nothing? No reference to primitive variable in dev mode? So I have to keep “cheating” with a mix of variables and styles as it gives better overview of primitives in use! 😮‍💨
George_B1
Aug 3, 2024 5:00 AM UTC
How do you apply this “hack” if the semantic variable you added the code syntax to is part of a variable with multiple modes with different variables?
the code syntax is applied per variable, not per mode 😦
