Lucas_Miqueias
Hot reload not working with React
I’ve been trying to use Hot Reload for a while now but it doesn’t update.
I always need to reload the plugin.
Is there anything I can do?
ezgif-2-b0e7e698b3
ali_yousefi
July 12, 2023
I have the same issue…
July 20, 2023
Same issue here. Not sure what needs to be done. The hot reload plugin option doesn’t get checked as per the documentation
July 25, 2023
I have same issue.
Colin_Wirz
I have the same issue. Figma is only watching if the manifest.json file changed. So if you want to hotreload the plugin just change the manifest file or make sure the file gets updated somehow every time your build tiggers so the changed date and time of the file is new and Figma will reload the plugin.
Lucas_Miqueias
This makes sense and sad at the same time. 🥲
Colin_Wirz
It gets checked but only when you access the menu via rightclick somewhere and then you can select hotreload.
Lucas_Miqueias
Ok, but this isn’t productive.
Is there any alternative?
Pop_Razvan1
August 15, 2023
Does anyone have a solution for this ?
October 20, 2023
I faced the same issue but it was from Webpack, not React.
Adding cache: false to HtmlWebpackPlugin fixed the issue of my dev environment.
Lucas_Miqueias
This not working for me.
My files ui.js and main.js are updating, but the Figma not listening.
