Barony
Mar 4, 2025 1:09 PM UTC
Help please
So guys, I'm new to Figma and I need a little help. I really don't know how to explain this, but when I'm in the prototype view and I hide that part of the component, the component below doesn't follow the top, how can I sove this?
    Sergio NC
    Mar 8, 2025 8:52 PM UTC
    Hi there,
    I am new to Figma too. However, if I understand correctly, you mean that the arrow pointing downwards doesn’t return to its original state after the dropdown “returns” to the top component, right? I was facing this issue until I noticed the “Reset component state” 👇
    This should reset the component to its original state after the interaction takes place. That is, the arrow will point to the right again.
    Ideally, you will be able to check this option after you set a “Change to” interaction. In my case, it doesn’t always happen, which can be problematic.
    Hope this helps!
    Sergio
