Corey_O_Brien
July 14, 2023
Help needed for a widget. Invalid syncedState value
  • July 14, 2023
  • 5 replies
  • 281 views
I can use my widget just fine, both in dev and in prod, but when other people try to drag it onto a canvas they get the following error.
Error: in setSyncedState: Invalid syncedState value for widgetID=1255306792807530830 name=name value=undefined
at (PLUGIN_5_SOURCE:260)
Why does this work for me but not other people and what can I do to fix it? Any help would be appreciated.
tank666
July 14, 2023
Check line 260 of your widget.
Corey_O_Brien
July 14, 2023
I found the problem but haven’t fixed it yet. I was doing this “figma.currentUser.name.split(/\s*,\s*/)[1]” which worked for my name but not for others. it is assuming the format of people’s names and not all names match the format of mine.
Corey_O_Brien
July 14, 2023
Yea was doing it but it really didn’t have to do with line 260 🙂
tank666
July 14, 2023
You probably checked this line in the .tsx file, but you should have done it in the compiled .js file.
Corey_O_Brien
July 14, 2023
Possibly :P. It did give enough info to start troubleshooting though. I was using the second value after splitting up the string. Some people don’t have a comma separated name so their name didn’t have a second value after the split. I needed more conditional in there or in my case I just took out the split for now and used the whole username.
