jason senger
Sep 24, 2026 6:20 PM UTC
Glass effect losing opacity when copy and paste
We have a graphic with 2 frames that are using the glass effect.  (see screenshot: original).
~ when it is selected and dragged / copied, it duplicates fine (see A)
~ when it is copy / pasted within the figma design or between two separate figma designs, the glass effect opacity is lost. (see B)
hoping there is an easy solution that i can’t find…..thanks in advance!
adamsmasher
adamsmasherSolution
Sep 24, 2026 9:22 PM UTC
Ok, thanks for confirming! I tested this in the desktop app for mac OS, and the effect was retained when I did both optIon + drag (like you saw) and copy/paste. Are you using the Desktop app or a browser, and what operating system are you using?
For my test, I had a frame using a background image fill, then on top of it was a basic rectangle with a 25% fill and a glass effect with default settings.
A screenshot showing the results of click/dragging and copy/pasting a layer with glass effect applied.
The bottom, selected layer was created by copying and pasting. Hmm… are you copy/pasting a component, or just a selection of layers?
adamsmasher
Sep 24, 2026 6:37 PM UTC
Hey, ​@jason senger! Thanks for your post and the screenshot - it’s helpful for understanding what you are seeing with copy/pasting versus dragging.
Could you check whether the pasted frame still shows Glass under Effects, and whether its fill opacity matches the original? A fill at 100% can hide the Glass effect (this is mentioned in the Apply Effects to Layers help article). Also, just to be super clear, this is Figma’s Glass effect and not a custom shader, right? I can take this issue to the team once I have a bit more clarity. Thanks!
jason senger
Sep 24, 2026 6:49 PM UTC
​@adamsmasher - correct on both.  the fill of the pasted frame changes to 100% opacity.  the original frame fill has 20% opacity.  and yes, using the native Figma Glass effect not a plug-in.
thank you.
adamsmasher
adamsmasherSolution
jason senger
Sep 24, 2026 9:52 PM UTC
​@adamsmasher - it was a group that i was copy/paste when the glass effect was losing it’s opacity.
i just changed to a component and now when i copy/paste it works correctly….glass effect isn’t lost!
I didnt know about component until your post - new to Figma, coming from Adobe Suite background.
thank you so much for your assistance - really appreciate it!!
adamsmasher
Sep 24, 2026 10:15 PM UTC
Not a problem, ​@jason senger, and welcome to using Figma! Glad to hear that using a component resolved the issue for you. Since you are new, you might want to check out Figma Learn for help articles and videos on using Figma - there’s a lot there that can help someone new to Figma as well as experienced users.
Cheers!
Brent Hartford
Oct 2, 2026 12:34 AM UTC
​@jason senger I just had this exact experience. Glad that converting to a component was the solve. I had tried doing that but strangely didn’t work for me. My solution that happened to work was to delete the glass effect>undo. This seemed to re-render the glass effect properly.
