Caroline Mue
May 5, 2025 9:02 PM UTC
ghost image while jumping from frame to frame
Hi there.
I try to explain what the problem with the prototype is:
I have build a prototype with a slide menu, meaning when you press the burger symbol, a side navigation pops up, where i have implemented an image at the bottom. That’s working fine, when I open and close the menu.
Now the problem occurs when I use the second navigation option (the bottom navigation bar) on the home screen. This image, that I implemented in the side navigation, apears as a ghost image for some milliseconds on the next screen in presentation mode, while tabbing from “Home” to “Favorites”, from “Home” to “Cart” and from “Home” to “Profile”.
I used smart animate to have smooth transitions, and everything works fine, beside that bottom nav bar with the ghost img appearing on the next interaction.
I also want to keep that smart animation for that bottom nav bar, but the image only dissapers on the next frame (favorites, cart, profile) if i set it to instant, which is not i was looking for, because there is no smooth transitions on the bottom nav bar anymore.
I rebuilded that occuring in the screenshot, this is how it looks like in presentation mode.
ghost img on the right frame
Do you have an idea how I can fix this? How can I still leave it at smart animate without the ghost img on the next screen?
