Apr 4, 2023 11:25 PM UTC
Getting error: "Property 'hyperlink' does not exist on type 'TextNode'"
I am creating a custom Table of Contents app for my org.
I have an array of page nodes called section.
Here is my code:
section.forEach((name: string, id: number) => {
  let pageLink = figma.createText();
  pageLink.fontName = { family: fontName, style: "Regular" };
  pageLink.characters = name;
  pageLink.hyperlink = { type: "NODE", value: id };
  pageLink.textDecoration = "UNDERLINE";
  pageLink.fontSize = 16;
  sectionFrame.appendChild(pageLink);
When I remove the hyperlink, it works fine. When I don’t, the process fails and nothing is rendered to the page.
I have console logged name and id inside the loop and it returns good values.
From what I can see in the API docs (and other plugins) this is the correct syntax. Is there some other factor that causes hyperlink to not be available?
tank666
Apr 5, 2023 9:23 AM UTC
Could you clarify what your array of page nodes looks like?
Are you sure this line is correct: section.forEach((name: string, id: number) => {?
Also note that the hyperlink id must be a string, not a number.
Apr 5, 2023 2:00 PM UTC
Thanks for the response.
So what I’m trying to do is take the list of page nodes, and chunk them up into sub arrays (“sections”) based on a string prefix on some of the pages ("— ").
Here’s how I’m doing that. (I’m not a developer so this might look amateurish)
 let pages = [];
let pageIds = [];
figma.root.children.forEach((page) => {
      pages.push(page.name);
      pageIds.push(page.id);
const pageSections = [];
let sectionArray = [];
pages.forEach(page => {
  if (page.startsWith('--- ') && sectionArray.length !== 0) {
    pageSections.push(sectionArray);
    sectionArray = [];
  sectionArray.push(page);
pageSections.forEach((section) => {
  createSectionItem(section)
It seems like this is where the problem is. How can I pass through the page ID to use for the hyperlink?
Apr 5, 2023 3:05 PM UTC
Update: Got it figured out. Here’s my new code…
  const newArray = [];
  let currArray = [];
        if (page.name.startsWith('---') && currArray.length !== 0) {
          newArray.push(currArray);
          currArray = [];
        currArray.push(page);
  newArray.forEach((section) => {
      createSectionItem(section);
createSectionItem loops through each “section” sub-array, which includes a list of nodes that have page.name and page.id so I’m able to create hyperlinks now.
Thanks again.
