mishakoltov2
August 4, 2023
Gaps in text when using "text align justified"
Hi! I faced with problem of different sized gaps between words in text block with fixed width. I need to use text align justified (so I can’t solve this problem using text align left). In text block above you can see original version of text block with large gaps. In the text block below, I solved the problem by dividing a some words into syllables manually. Is there any way to automatically use text align justified without problem of different sized gaps in Figma? Is there maybe other programs where I can add desired text on empty Figma’s frame? (I’ve already searched the entire Internet but I haven’t found anything other than manual hyphenation 😦 )
