VenusB
Jun 21, 2026 4:33 PM UTC
Frame at 1280px width looks blurry in Present mode
A frame that is 1280px wide looks blurry in Present mode (text and vector elements lose sharpness). Other frames in the same file, for example, a 1080px wide frame look perfectly sharp in Present mode, on the same machine, same display, same session.
My laptop's native display resolution is 1366×768
Checked AMD Radeon Software (integrated graphics): GPU Scaling is Off, Scaling Mode is set to Center. Disabled Virtual Super Resolution as well — no change.
The content inside the 1280px frame is 100% vector and text, no rasterized images involved
    Jun 22, 2026 6:37 AM UTC
    Hi ​@VenusB,
    I understand you're experiencing blurriness in Present mode on a 1280px wide frame, while other frames in the same file appear sharp.
    I looked into this but wasn't able to find a similar reported issue or a known solution at this time. To help narrow things down, could you try the following when you get a chance?
    • Is this happening in a supported browser, the desktop app, or both?
    • Try switching to a different scaling option from the Options menu and see if it makes a difference: Play your prototypes
    • Are any blend modes applied to elements in the frame? Apply blend modes to layers, fills, and effects
    If the issue persists, please send me a PM(Click the profile icon on this message → mail icon) with the file URL and your findings from the troubleshooting steps above, and I'll go ahead and connect you with our support team to investigate further.
    Thanks!
