djvSolution
Aug 30, 2022 11:17 PM UTC
Hey All,
This is a long standing bug that our engineers have been continuously logging and trying to fix. This generally only happens on icons imported from other apps, where the mirroring on the points is reversed or missing.
Right now, the best workaround is to rebuild affected icons from scratch. Please note that redrawing with fewer points can also help.
While we can’t guarantee an ETA on a fix/improvements, please know that our team follows this thread and takes everything you provide into consideration.
Matt_Nish
May 26, 2024 4:39 PM UTC
Worked for me too, thanks Miquel!
Adzetko_Hohengarten
Jun 3, 2024 7:55 AM UTC
I just tried but my vector was already using a round join, and it still does not work for acute angles, just break the outline and create inner straight lines instead.
The round join workaround works fine with circles though!
MJ_Holland
Jun 25, 2024 5:32 PM UTC
Seems this is the way (I just had to go from 72 width to 500 though)
Jul 1, 2024 11:13 AM UTC
Thanks a lot, works for me as well! Btw, I think this issue is not necessarily related to the bug about broken export output, that many people mention in this thread
Bez1
Jul 31, 2024 12:58 PM UTC
it’s a nice trick if you make a closed design in Figma and export it as is, but it’s not a real solution. if we need to make an icon to work in a web environment that would scale proportionally, this trick won’t work. some of us prepare the SVG in Figma (instead of opening illustrator) and we want our icon/logo sizes would be “baked” in, there is a reason outline stroke exist…
Niclas
Aug 16, 2024 8:37 PM UTC
It’s been over 3 years and yet it’s still the same bug… 😕
Nicolas_Python
Aug 19, 2024 10:54 AM UTC
I solved the issue!
Description: We use streamline Illustrations and had the same issue. Outline stroke created some really weird results. Therefore I went down the rabbit hole and found a script that is called oslllo-svg-fixer. My approach works for Macs.
Solution: I exported all SVGs that only had strokes from Figma to a folder on my desktop. Let’s call it “SVGSTOFIX”. I then used co-pilot to write a script in python that takes all my SVGs from SVGSTOFIX, replaced all blanks with underlines in the filename and then uses “oslllo-svg-fixer” to create SVGs that have no strokes anymore but fills.
Preparation: Make sure that your SVGs contain only one stroke. You do that, by selecting an SVG, remove all groups inside the SVG, select all strokes inside the SVG and then hit Option+E to simplify the stroke.
Then:
  1. Create a folder on your desktop, named SVGSTOFIX
  2. Create a folder on your desktop, named FIXED
  3. Install homebrew by opening Terminal and type: /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
  4. Install python using the following terminal command: brew install python
  5. Install TQDM using the command: pip3 install tqdm
  6. Install Node using terminal: brew install node
  7. Install oslllo-svg-fixer: npm install -g oslllo-svg-fixer
  8. Download the python script attached Python Script to convert SVGs from stroke to fill. and save it to your desktop
  9. Open the file and edit the source and destination folder, so your folders will be found. If you’re not sure how to find the path to your folder, simply drag your folder into the terminal and it will show you the exact paths to use. The part to edit looks like this: source_folder = '/Path/to/Desktop/SVGTOFIX' destination_folder = '/Path/to/Desktop/FIXED/'
  10. make sure, that everyone has read and write rights on the folders. To do so, right click on the the folder and edit access rights. Everyone: read and write.
  11. Final step: in terminal write python3 and then drag the fixIcons.py file into your terminal. It should look like this: python3 /Users/xy/Desktop/python.py
  12. Hit enter and watch the magic work.
  13. When it’s done, drag the created SVGs from the folder “FIXED” into Figma. Adjust the fill of the SVGs to your preferred color and from there you do whatever you want. Create components or simliar.
I know this seems rather complicated. Therefore I’m thinking about providing this as an online solution. Leave a comment if you want me to do so.
JuliesZ7
Aug 20, 2024 4:22 AM UTC
Hi guys, I just discovered a way to fix this issue. I’ve found that every point without a handle or missing a part of a handle will trigger the bug. You just need to hold Ctrl and create the handle for it, then you’re good to go.
Nicolas_Python
Aug 20, 2024 2:04 PM UTC
That would be a lot of handle creation with our Illustration set of 5000 Illustrations 😉
Josiah_Gatlyn
Aug 21, 2024 5:11 PM UTC
Hello, this bug still exists
