djvSolution
Aug 30, 2022 11:17 PM UTC
Hey All,
This is a long standing bug that our engineers have been continuously logging and trying to fix. This generally only happens on icons imported from other apps, where the mirroring on the points is reversed or missing.
Right now, the best workaround is to rebuild affected icons from scratch. Please note that redrawing with fewer points can also help.
While we can’t guarantee an ETA on a fix/improvements, please know that our team follows this thread and takes everything you provide into consideration.
Chaine
Aug 30, 2023 12:57 AM UTC
I can’t believe such simple path would fail…
natchi
Sep 6, 2023 4:33 PM UTC
Guys!!! I found it! After all this time!!
Three steps:
  1. Export your SVG icon/path with the stroke. Next to the export settings there are three dots. Press them → DISABLE Simplify Stroke
  2. Head to this website to covert the stroke to a fill: https://iconly.io/tools/svg-convert-stroke-to-fill
  3. Drag and drop the converted SVG shape into your project and use it as a combined shape!!
Fixed! (Easy workaround-ish) 😀
deletedlc
Sep 27, 2023 12:54 PM UTC
cannot believe we are approaching 2024 and this is STILL NOT WORKING
stop telling me I need AI or some other websites to complete such a SIMPLE thing
Oleksandr22
Oct 3, 2023 10:13 AM UTC
I found a solution, that works for me! The plugin is called “Path Offset”. You just need to set a negative number as offset value. Hope this helps
DeAnna
Oct 9, 2023 7:35 PM UTC
Is this being worked on currently, or do we need to submit a new request?
Marcus_Vedde
Oct 17, 2023 11:29 AM UTC
This works for me: Press “K” and upscale to x100 and apply outline. Upscale more before outlining if the result is bad. Sometimes extra points are generated but usually thats fine.
Then reverse the size by pressing “K” and scale to x0.01 (1 / upscale).
I have not tested this on complex shapes!
Jaffar_Kazmi
Oct 29, 2023 9:46 PM UTC
Thanks a bunch, just used your tip and it worked. Surely u saved me a lot of time, Thanks ❤️
Stefan_Brigola
Nov 4, 2023 10:34 AM UTC
A really major topic not fixed since February 2021???
WHY?
It produces unnecessary extra work. At least an explanation would be good, so we know why this is not solved yet. Thank you.
I am quite surprised this has only 25 votes 🧐
Stefan_Brigola
Nov 4, 2023 10:48 AM UTC
Thank you for the advice. In my case it does not work – I don´t get it why Figma is creating this extra lines like here:
Vla_Dunev
Nov 7, 2023 10:06 AM UTC
Hey, Figma, are you sure someone is working on this?
It’s prety obvious that your whole vector system is complete crap, this issue is only one of many. Any plans on reworking it finally?
Or Adobe has oher priorities than a working program?
