Fix Outline Stroke
  • February 28, 2021
  • 103 replies
  • 37571 views
Show first post
Johan_Lilja
  • November 13, 2023
This so frustrating. Either fix the feature or remove it.
let’s keep this thread alive
Marcus_Vedde
  • November 28, 2023
Sorry to hear that. Figma often created some extra points for me to, but I had no issues with it.
rigayaya
  • November 28, 2023
still have the problem 😭
Marcus_Vedde
  • December 13, 2023
I’ll do a test if you could send me the SVG-code. It doesn’t look to complex.
Haadee_Bin_Hafees
guys just deselect the simple stroke option when exporting the svg in the three dots page. idk why its automatically selected either.
Jordan7
  • December 28, 2023
How do you get these options they don’t appear for me
Haadee_Bin_Hafees
the options only appear if u actually have a stroke in place already. not sure what the other options are.
Miquel
  • January 5, 2024
I found the logic behind it and, therefore, a sloppy solution.
Figma needs a higher resolution to Outline the Stroke.
Making it HUGE(ex 5000px x 5000px) and then converting the stroke into a path has been working for me.
  • January 9, 2024
you are right, I just tried and it worked perfectly, I increased the size of the icon and then converted. Thanks
Adzetko_Hohengarten
I frequently encounter this problem with strokes set to “middle” or “inside”.
I can’t really figure out an universal way of preventing those crazy straight lines, sometimes deleting them manually does the trick, sometimes it destroyed the whole outlined path. Scaling helps, but sometimes isn’t enough.
I’ll leave you with a case from this morning, took me 30 minutes to do something that should work with a click:
Sebastian_Gallego
Having the same issue with no matter how simple the lines are. It feels it gets worse when adobe bough it
Tamir_Pomerantz
Keep this thing alive
alejandro_mateus
Maybe it’s not the best but it works for me, I converted the icon in outlines in this web and then I used it in Figma, I hope it works for you.
https://iconly.io/tools/svg-convert-stroke-to-fill
Sebastian_Gallego
How can this still not be addressed ? 2024 and I STILL HAVE THE SAME ISSUE. with simple shapes.
Airwrecka
  • February 16, 2024
This bug is bugging me! Found no other workaround than simply NOT use the “outline stroke” action in Figma. I have to do it in Illustrator beforehand 😦
Update: I have found out that you can resize vector images in Figma (press the “K” key). The outline changes proportionally to the size of the vector image. So I no longer have to convert vectors in Figma and the bug no longer bugs me. :D:D:D
Remy_B
  • March 13, 2024
Unfortuately this issue is still an issue. The workaround by upscaling it 100x and then outlining the strokes works. But quite tedious. Just keeping this post alive!
Markus_Girlinger
This long lasting bug is so frustrating. We spent hours over hours looking for a solution or a workaround. Not even the upscaling to 100x is helping. We have to copy every icon to Illustrator to have it outlined.
Daniil_Pronin
I just use InkScape when Figma cannot do some vector thing.
  • April 2, 2024
A tad bit tedious, but I found a SOLUTION using two free plugins that works with intercrossing strokes and actually flattens the shape properly. Not sure if anyone found this or a better solution, though, there’s no way I’ll read all of that above.
The example path I’m using is so complex using “Outline Stroke” doesn’t just tangle the shape, it straight up makes it disappear. Here’s the workaround.
First, separate the path to segments with the plugin “Split Vectors” by our first king Neil Akhmetov. This will create a crap ton of simple lines that can handle the conversion.
Figma
WARNING! If your shape is as complex as mine, be sure to flatten them in smaller segments before flattening the whole thing to avoid tangling up the shapes or making it disappear.
There you go! Not the most ideal solution, but we work with what we have. You are most welcome to worship me now. Comment if you stumble upon an issue while using this method, though, maybe there is something I’m missing. Good luck, people~ 💜
Marcus_Vedde
  • April 8, 2024
Maybe try to put all objects in an auto-layout, and select all of them when doing the steps. If some fail, take them out and do them seperately.
Marcus_Vedde
  • April 8, 2024
This works for some. The method doesn’t involve third party plugins:
  • April 12, 2024
Any news? I’m working with a design system and there’s a shit ton of icons I need to flatten. Why does this have to be so complex?
irina.ursache1
Still an issue…
Lol, if the feature doesn’t work then don’t keep it in the build. Can’t even convert this basic shape…
