djvSolution
Aug 30, 2022 11:17 PM UTC
Hey All,
This is a long standing bug that our engineers have been continuously logging and trying to fix. This generally only happens on icons imported from other apps, where the mirroring on the points is reversed or missing.
Right now, the best workaround is to rebuild affected icons from scratch. Please note that redrawing with fewer points can also help.
While we can’t guarantee an ETA on a fix/improvements, please know that our team follows this thread and takes everything you provide into consideration.
Adzetko_Hohengarten
Dec 20, 2024 1:46 PM UTC
You’re the best, thanks for sharing it!
simgust
Feb 5, 2025 7:38 AM UTC
Still an issue that I face regularly!
I can always get around it after som fiddling, but it’s annoying. Seems like the “scale things up a lot, outline stroke, scale things down again” method is an okay workaround for now.
richy
Feb 11, 2025 8:33 AM UTC
I found the logic behind it and, therefore, a sloppy solution.
Figma needs a higher resolution to Outline the Stroke.
Making it HUGE(ex 5000px x 5000px) and then converting the stroke into a path has been working for me.
Worked perfectly in my case and is much quicker than firing up Illustrator. Now I just have to remember that hack. Thanks ​@Miquel !
