Floran
Mar 2, 2023 10:04 PM UTC
Find all instance coming from the same component
Hey !
I would like to do something on every instance of a same component, coming from an external library.
Let’s say the component is named “XYZ” and has multiple variants.
I know that I need to use *instance*.mainComponent.parent.name to get the name of the component, because if not it gives the name of the variant (xxx = xxx, yyy = yyy …)
But when I use it as a search criteria, it’s not working :
const instances = figma.root.findAll( elem => elem.mainComponent.parent.name === "Spec guides");
I get the error :
Error : “findAll” callback crashed: TypeError: cannot read property ‘parent’ of undefined
How to do it properly? 🙂 Thanks !
PS : I tried to use the name of the instance. It’s working, but sometimes we rename the instance so it won’t work in this case…
tank666
tank666Solution
Mar 6, 2023 7:12 PM UTC
node.mainComponent && node.mainComponent.remote && node.mainComponent.parent && node.mainComponent.parent.name === 'something'
Floran
FloranAuthor
Mar 5, 2023 12:35 PM UTC
This doesn’t look working for me :
const instances = figma.root.findAll( node => node.mainComponent.remote && node.mainComponent.parent && node.mainComponent.parent.name === target);
console.log(instances);
Error: in findAll: “findAll” callback crashed: TypeError: cannot read property ‘remote’ of undefined
Floran
FloranAuthor
Mar 5, 2023 12:36 PM UTC
Make sense, maybe not optimal.
tank666
tank666Solution
Floran
FloranAuthor
Mar 7, 2023 8:52 PM UTC
Thanks a lot, this works. So if I understand, I need to check that all the values exists in any case.
Mar 21, 2023 2:12 AM UTC
I just want to point out that optional chaining makes this a lot nicer:
node.mainComponent?.remote && node.mainComponent.parent?.name === 'something'
