Best_PK
Feb 8, 2026 2:58 AM UTC
Figma workflow question: Branch vs main design library for dav handoff?
I’m trying to improve our workflow for handing off new and updated design system components to developers. When a new component is “ready for dev,” is it better to:
  1.  Share a separate design file or Figma branch for developers to build from, or
  2. Merge/publish it into the main component library/design system first, then share?
In our case, once designs are shared, it can sometimes take 3-6 months or more before developers actually pick them up. Because of that delay, it becomes hard to tell:
  1. Which components are truly “ready to use” vs still conceptual (waiting to be built)
  2. Which ones are already built vs just designed
This creates confusion around the source of truth and readiness. I’m also wondering whether new components that are “ready for dev” should live in a separate space from the main design system library until they’re actually built, to avoid mixing shipped components with components still under development.
My current thinking is that new components would live in a separate file (outside the main design system) while they’re being designed and reviewed, and only move into the design system once it's built. For enhancements to existing components, we’d create branches from the design system and merge back once finalized?
However, this loops back to the main challenge I’m trying to solve: how do teams clearly track status and maintain a single source of truth, especially when development can take months? Right now it’s hard to tell which components are ready to use, which are still pending development, and which are officially part of the design system. That confusion makes onboarding harder and creates uncertainty around what designers should actually be using.
I’m curious how other teams handle this. Do you keep “ready for dev” components separate from the design system until they’re built? Do you use statuses, release notes, or another method to avoid mixing shipped components with those still in progress? I apologize for the long message. I am looking for best practices from the experts :)
