Jul 5, 2024 3:58 PM UTC
Figma Slides: publish template error
When I try to publish a Figma Slides template, I get this message:
“Something went wrong while publishing. Refresh the page and try again.”
I’ve restarted Figma and have re-tried a number of times. Can you suggest anything? Thanks
ksn
Sep 9, 2024 6:13 PM UTC
@ValentinaG @Jeffrey_Potter – are you both still having trouble with getting your slides published? If so, can you reply with the name of your deck file? We’ll look into this further.
ValentinaG
Sep 11, 2024 5:47 PM UTC
Hey there, unfortunately I’m still having the issue. My deck file is named Halo Design Systems Template, let me know if I can provide any further details.
Sep 13, 2024 6:40 AM UTC
Hey @ValentinaG , thank you for the details! Can you please also share the URL of the file here, and add support-share@figma.com as an Editor, so we can take a closer look? Thank you!
Gayani_S
Sep 17, 2024 1:56 PM UTC
Hey @ValentinaG, wanted to ask again if you’re able to provide a direct link to the file here, and invite support-share@figma.com with “can edit” permission so we can look into this further?
Note that users with @figma.com emails on your team do not count towards your billing.
Thanks!
ValentinaG
Sep 17, 2024 3:29 PM UTC
Sure, this is the link to the Slides file with edit access given to support-share@figma.com.
Let me know if there’s anything else I can do to help identify the issue.
Gayani_S
Sep 18, 2024 1:37 PM UTC
Hey @ValentinaG, thanks a lot for providing the link. I’ve forwarded this to the team and I’ll update you soon.
Appreciate your patience in the meantime!
Mason_Grishin
Oct 11, 2024 10:46 PM UTC
Looks like the slides with “Master component” inside, can’t be published. @figma Can we fix that?
Gayani_S
Oct 15, 2024 1:16 PM UTC
Hey @Mason_Grishin, I haven’t heard back from the team regarding the previous issue. However, I’ve reached out to doublecheck if this is caused by master components in slides. Will give you an update asap.
Gayani_S
Oct 23, 2024 12:40 PM UTC
Hey everyone, apologies for the delay in updating you!
The team has confirmed that, at the moment, we don’t support publishing a slides template that contains a component. As a workaround, we recommend creating an instance from the component and using that in your slides file.
We know this isn’t ideal, and the team is actively working on a solution. It’s a tricky issue, so while we hope to roll it out soon, we don’t have a specific timeline yet. I’ll keep you updated as we make progress!
Thanks for your patience, and feel free to reach out with any questions.
Nov 10, 2024 9:57 PM UTC
I published a Template for my team and then went in to make some changes now I am getting this notification ‘Figma slide templates cannot include components please move them off the slide before publishing’ what has changed?
